Brasov won the supercharger voting in 2023
According to this article, the location for the Supercharger will be: 45.632917, 25.636935
Any updates?
Status?
waiting for approvals, I guess.
NOW it is 2025 but the Stalls are still not installed.
Supercharger in Buzau is ready and Brasov hasnāt even started. Romanian bureaucracy, supply chain issues or poor planning?
[quote=āmihainegru, post:6, topic:2857ā]
Supercharger
[/quote] Two years and counting. Nothing changed!
anyone from the area has some updates?
will be built in another location
nice, thank you, do you know where?
Chargers are installed but are not working as of today. Also, they do not appear on the Tesla map. While Iām happy they finally got the approval to install them, they look and feel super cheap (Iām not being a snob⦠however, this raises concerns around durability and ease of use). They are not comparable with the ones already installed everywhere, nor with the ones from Eldrive which have the pivot arm. Also, the way they are installed makes them super difficult to use. You will understand once you try to use them. They are mounted parallel to the parking space (e.g., reverse park next to one, on your left, and try to use it). The cable is short. So, basically, your car needs to be parked half in the parking spot and half in the street. I believe they were meant to be mounted either perpendicular or at a 45-degree angle. As with everything made or installed in Romania, nobody cared to do a POC to understand if the placement will work or not. But hey, at least we finally have them :)ā¦
Not only do they look cheap, they are! Tesla has the cheapest charger per post, at about 25k $. That is part of the reason they can build so many so fast. They have been installing this model (v4 stall) for over a year now all the world. As for for the position, this has also been used before, it has nothing to do with Romania.
Does somebody have any idea when they are going to open it?
Itās up and running!
someone update it on the map
